I noticed the problem while replacing the control panel. Thought about putting some foam behind the vent trim but I'm worried it will burn up. Not sure if the vent is for air going in or coming out but I guess it's an inlet.
Use a small rubber hose or flexible tube and place one end near or on the dust. Blow thru the other end. The dust might have some grease in it, use toothbrush or small long bristle brush, similar to a baby bottle brush but much thinner, to help loosen dust.
Do not add insulation!!
If it's a convection oven, the vent might be intake. Most vents are exhaust. Does heat come out of it during use?
Is it fan induced? Put a piece of paper near it, does the paper get sucked in or blow outward?
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
