If I read everything correctly in the manual I believe the light only stays on when the device is in the pairing mode. If the light flashes every second, the headset is on a call, if the light flashed every three seconds, it is in standby mode.
Standby mode: is when the Jabra BT160 is passively waiting for a call. When you 'end' a call on your mobile phone, the headset goes into standby mode.
Make sure your phone is bluetooth equipped.
You must first successfully pair the headset with your phone. The manual shows you how.....
1. Put the headset in pairing mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT160 Follow your phone's instruction guide. This usually involves going to a 'setup,' 'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover' or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT160 Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Go here for a copy of the owners manual....
http://www.mainresource.com/PDFs/GNBT160User.pdf
Hope this helps.....
