How do I add a handset to a Telstra V580A cordless phone system
My current system has only 2 handsets but according to the instructions you can add up to 5 handsets, I have 3 handsets from my other system which is the same but the base station has surged.
If the message light on the Telstra cordless handset 1 is flashing, indicating a new message, but the message light on handset 2 does not flash even when it's on the cradle, there are a few troubleshooting steps you can try:
Check message notification settings: Make sure that the message notification settings on both handsets are properly configured. Refer to the user manual or the settings menu on the handsets to adjust the message notification settings. Ensure that the notification is enabled for both handsets.
Reset the handsets: Try resetting both handsets to their default settings. This can be done by removing the batteries from the handsets, unplugging the base station, and leaving them disconnected for a few minutes. Then, reinsert the batteries and plug in the base station. Allow the handsets to reconnect to the base and check if the message light on both handsets functions properly.
Check the base station: Ensure that the base station is functioning correctly. Check if the base station is properly connected to the telephone line and power source. If possible, try connecting handset 2 to the base station that handset 1 is connected to and see if the message light functions on that base station. This will help determine if the issue is with the base station or the handset itself.
Contact Telstra support: If the issue persists after trying the above steps, it may be best to contact Telstra support directly for further assistance. They will have specific knowledge of their product and can provide more detailed troubleshooting steps or advise on any potential repairs or replacements that may be necessary.
Remember to refer to the user manual for your specific Telstra cordless model for more detailed instructions on troubleshooting and operating the handset.
Place the telstra 8100 handset in the charger. Call any number while the handset is in the charger and it should dial out - you can hear the dial tone now. Take the handset out of the charger and you should be able to call normally.
cheers Matt
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect. Good Luck Doc
