Heating & Cooling Logo
G
George Evans Posted on Jan 02, 2015
R410A ducted system, Filter word shows on panel of conroller. Cleaned filter. How do I cancel the filter word on panel?
Looked through lots of manuals on line and can't find this particular controller. Tried the Mode button and got to see test/exit, service word but cant move on with arrows of any other button to see other modes.
Vincent Schnittert
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Jan 03, 2015
Vincent Schnittert
Contributor
Level 1:
New Friend:
Answers
40
Questions
Helped
12313
Points
66
Look like you talking about your t stat what kind of t stat if Honeywell need to know the typeof tstat
I’m happy to help further over the phone at https://www.6ya.com/expert/vincent_f7b7c5f4dedd2565
4 Related Answers
Anonymous
  • 26 Answers
  • Posted on Apr 01, 2008
SOURCE: ERROR CODE
Hi,Pls to shut - down the unit and try to power on ,may be its malfunction the control LCD.
THANX
Edgz
Anonymous
  • 141 Answers
  • Posted on Aug 11, 2010
SOURCE: got a pyrox comfort control
on the reset switch there should be a temp. cut out take a temp. reading and see if it is realy getting as hot as the switch is rated for maybe the switch is bad
Anonymous
  • 43501 Answers
  • Posted on Apr 24, 2011
SOURCE: a r410a central system requires
Okay... I hope I get all of the questions for you....
First....no the filter can be anywhere in the system....but are you using s liquid line filter or a suction line filter....often you will use a liquid line filter and in that case the arrow would be pointing away from the condenser as the liquid is flowing from the condenser...
Next... pressure test the line set with the nitrogen with the service valves closed. Also pull the vacuum with the valves closed....break the vacuum with nitrogen and then pull the vacuum again....then break the vacuum with R-410a refrigerant before opening the service valves....
Then check your temperatures and pressures to see if more refrigerant is required... make sure that you have normal outdoor and indoor temps when checking the pressures and adjusting the charge.
Any other questions just comment back!!
heatman101
Anonymous
  • 89 Answers
SOURCE: My thermostat conroller mode button that changes
try to open the front panel, then look for the reset button inside the electronic board, then press it once. You will see all the LED lit randomly then press the test button. i hope this would help thanks.
1helpful
Where is the filter on my Central Cooling Air Conditioner York LR49182C (Serial no. EFFS160427) (Model no. M/HD036SC) ?
Your furnace filter or A/C filter is located next to the floor in your cold air return into the furnace. Your other problem is your condensate line out of the A/C box that sits on top of your furnace is plugged. Replace your filter in the cold air duct, and remove your condensate line from the A/C box and blow air in the line to remove the clog in the line.
Always air filter clean
If the light comes on after it\'s started its cycle, that sounds like your dryer actually has a sensor in it (my dryer just has a fake light to remind you to clean the filter, but there\'s no sensor).
Either there\'s debris accumulated inside that\'s blocked the sensor (it\'s working correctly), or the sensor itself has failed (part repair).
It\'s possible your filter itself isn\'t letting enough air pass through any more. Do a quick test: run the dryer with the filter out and see if the light still comes on.
If the light still comes on, see if you can remove some lint from the dryer. Remove the filter and get a vacuum nozzle in as far as you can to try to suck out any lint that got past the filter.
Also check the exhaust. How recently was your dryer duct cleaned? Could it be clogged? Disconnect the exhaust from the wall and inspect the pipe. If you see a *lot* of lint and dust it should probably be cleaned. It\'s not expensive - call a duct cleaning company and ask them to clean your dryer duct and nothing else. No addons, no extended service plan, nothing - just clean the duct.
By now you\'ve checked the air going in and the air going out. If it still continues this behaviour I would look at the sensor itself. It\'s almost certainly cheaper in the long run to call in a repair person for that.
Mar 03, 2014 • Dryers
2helpful
2answers
I washed, then dried a rug that instructs to "air dry." (Now I see the instructions for proper care...) I have A LOT of little rubbery pieces in the dryer and I have a fear of setting the dryer on fire...
even tho you've cleaned out the lint trap and the drum, small pieces of your rug have most likely passed by the filter, or thru the seam where the drum meets the front and rear panels. I would recommend pulling off the front cover, and vacuuming out the "innards" of your dryer. That way you can be confident that you're good to go. You can also remove the lint filter and with a vacuum edging tool **** out any visible "chunks" in the duct. Let me know if you need assistance opening up your dryer.
1helpful
Sometimes water doesn't get hot.
Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
1helpful
2answers
2helpful
2answers
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
R410a fan outside blows no air comes through ducts on the inside
the fan on the outsides job is to help reject the heat. listen to see if the compressor is running. It creates the flow of refrigerant in your system. Make sure your filter is clean and you may have to look at the evaporator(A coil). Its job is to absob the heat from your home
2helpful
What is error code c2 11?
Cabin Air Filter Under dash Kit
its on the intake area where the heater gets it air flow. in the shuttle area in engine bay under window.
Top Filter Heating & Cooling Experts
Paul Carew
NOEL
NOEL
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
