How do you change a headlight on a 2006 kia sedona?
Left front low or high beam headlight: remove battery, remove weather cap, pop-off 2-prong connector, depress spring holding bulb in position, use inspection mirror if necessary, one end of spring is caught beneath a lip, Move spring past lip and lift up, it will rotate upward and is fastened on opposite side. Remove old bulb, install new 55 watt halogen bulb (H7-55) available at Walmart. Install new bulb with tang in slot at bottom, fold over spring and depress to hook end under latch point, install 2-prong electrical connector, install weather cap, turn about 1/8 turn to lock into position. Reinstall battery, clean terminals and cable ends, place new no-corrode rings (available from Walmart) around battery posts, install cable ends, and tighten.
Right front headlights: not necessary to remove battery, otherwise same essential procedure.
Note: Lower and upper beams all use same H7-55 bulb.
