Watches Logo
Jagadish K Chandran Posted on Jan 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have bought casio edifice e0qs-a500 but its not working properly so i want to know how to reset to the default settings
I have searched in many websites but i can't get correct solution so please help as soon as possible
Randy Reynard
Level 3:
Master:
  • Master 623 Answers
  • Posted on Feb 11, 2015
Randy Reynard
Master
Level 3:
Master:
Answers
623
Questions
0
Helped
139580
Points
1016
Download the instructions for "factory reset" from the Casio Web site. You'll need to get the instructions for the module of your watch (which you can find on the back cover).
Testimonial: "but i can't find the factory reset instruction from the website so can u send me a link"
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Jul 17, 2008
SOURCE: I dont know how to
Hi Johny
You can get the instruction manual for your watch from here
regards
robotek
Anonymous
  • 111 Answers
  • Posted on Sep 02, 2008
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Anonymous
  • Posted on Oct 20, 2008
SOURCE: setting the analog dials on the casio edifice EFA 120
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Go here to get the instruction manual
Anonymous
  • 12 Answers
  • Posted on Oct 04, 2009
SOURCE: casio edifice mens watch user instructions needed
Go in alarm mode by pressing the mode button once twice...depending on the modes you have and then press one of the remaining buttons, usually top right button on most edifices. this toggles between alarm on and off. this shall do....
Anonymous
  • 2501 Answers
  • Posted on Aug 13, 2010
SOURCE: Bought a new Casio Edifice
It could be that you need to unscrew it before pulling it out (at feature that is sometimes used to give a better seal).
Turn the crown anticlockwise about 1/4 -1/2 a turn then pull.
Testimonial: "Thank You davidtolond. Your soultion was helpful. I am able to setup the time and date. Thanks for your help."
1helpful
6answers
How to reset time
Diplodocs - CASIO: 1506 references - Your user manual immediately available! Your CASIO has four push button and one for winding button. the first button has mark of LIGHT , the below button is MODE ,,upper right START/STOP,,, lower is LAP/RESET. the center button is what they called it a CROWN to set crown is just pull it and you can set the hour and minute. the LIGHT button is the set button also, just press it for 15 seconds if dial flashes, then go to MODE button and choose what going to set, the START/STOP -- LAP/RESET is the scroll button you going up and down the number or on /off ,some model of Casio Edifice, the set is in the MODE button just press it long and if flashes it ok. and follow procedure what i said before. setting cannot damage the watch. Feel free to ask question regarding your to watch so i can assist.. Hope this may help;
Regards,
VOTIT
Problem with day/date changes! My casio edifice
follow these instructions off the manual below if you set the watch in wrong sequens it wont change at 12 oclock
http://support.casio.com/en/manual/009/qw5125.pdfhttp://support.casio.com/en/manual/009/qw5125.pdf
Sep 27, 2013 • Watches
16helpful
2answers
Casio edifice EF534D, The seconds hand does not come back to 00 on pressing the reset button. what is the problem, how do i solve it??
Have you solved this yet? I have a reset process that sets the starting position back to 12 o'clock. Pull the crown to the second (outmost) position and then start pressing the start-stop button repeatedly. Each push will set the starting position by 1 second, until you get to 12 o'clock, then push the crown back to its normal position. Let me know if that works.
Sep 18, 2010 • Watches
1helpful
How to set my edifice EF528 manually, time setting, alarm ect...my uncle give me but eithout manual guide...it difficult for me to set all the functions.
Thank you for contacting Casio.<br /> You can download the manual direct from Casio. <br /> <a href="http://www.casio-europe.com/euro/watch/edifice/">http://www.casio-europe.com/euro/watch/edifice/</a><br /> Best regards.
Alarm Setting
Check if you are setting it for correct time with AM PM in consideration..
Casio Edifice Watch
Here is a link to the manual: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1310.pdf It says: Hold do the (A) button [the upper-right button] to advance the analog time setting. The analog time will adjust forward at high speed. It only goes forward, so if you miss the proper time, you have to go all the way around again.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
