We have watched many you tube videos. None show how to replace gasket with a built in water tube. Need to replace it soon.
The tube is usually only a push fit onto the filler nozzle. The tub to shell gasket (Door gasket) is different as some models do not have the gasket fill nozzle. This hose is for the recirculation pump (I think) The main filler is usually through the soap drawer at the top of the machine. The hose that is on an LG and on a Daewoo is only pushed onto the nozzle. The plastic nozzle comes out and off of the gasket.
SOURCE: replacing the door gasket on ge front load washer
very hard to replace if you hav not done it befor to get it installed correctly
SOURCE: torn gasket on a front load ge washer
Not too hard or technical. I followed John in Erie's instructions:
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
I bought my part at Appliance Zone. From what I paid and how long it took to get to me, I should have just bought it locally for a little more and had it delivered a lot sooner. Replacement took an hour and a half.
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
SOURCE: I need to replace the molding door boot seal on my
you need to first unplug the unit. next you need to remove 4 screws that hold the dispenser lid on. next open the door remove 4 screws. remove the door and the out side panel. next located to the top left and right you will see a bracket with a 5/16 bolt remove them and take the bracket off. next lift the lid. you will have access to the door seal. you will see a spring at the top that is the band that holds the seal to the tub. the front of the seal just peels off. when putting the band and spring back on may be a little tricky. get one side up to the top gett a piece of duct tape and secure it. so that you can properly get the rest of the band on without fighting with it. get some vise grips and pull the spring over and attach to the part that is tapped. let me know if this helps or if you need more instructions.
SOURCE: GE #WHDVH626 Front Loading Machine - Door gasket
Remove the top panel, the control panel, the toe panel, and the front panel to replace the door gasket. Disconnect power to the washer before servicing to avoid electric shock.
Remove the top panel by removing the top cover and the three 7-mm hex-head screws that attach the rear of the top panel to the cabinet. Remove the top cover by removing the three Phillips-head screws that hold it in place then insert a putty knife blade or similar tool along the top seam between the cover and the control panel. Lightly tap the cover off rearward; slide the top panel rearward then lift it off the cabinet.
Pull the dispenser drawer out until it stops; push down the locking tab, and then pull the dispenser drawer all the way out. Once the drawer is out, remove the Phillips-head screw from the recess of the drawer opening.
Remove the four Phillips-head screws that attach the control panel to the control panel cover. Release the tab on the right side of the control panel from the bracket inside the cabinet.
Lift the top edge of the control panel to release the three tabs that hold its top in place. Push the control panel towards the left, then release the side tab.
Label the wires and mark the connectors matching the wires before disconnecting the wires from the control panel.
Remove the three Phillips-head screws at the bottom of the toe panel holding it to the cabinet, then pull the toe panel down and off the cabinet.
Open the washer door, then remove the three Phillips-head screws holding the door switch and lock assembly to the front panel.
The door gasket is held to the lip of the door opening by a wire and a spring hidden in the fold of gasket. Grasp the wire at the spring location using a pair of needle-nose pliers and stretch the spring to clear the gasket, and then remove the wire and spring assembly. Peel off the door gasket from the lip of the door opening into the drum.
Remove the four Phillips-head screws that secure the front panel on its four corners to the cabinet. Lift up the front panel then remove it from the two hooks and all the way off the cabinet.
Pull down the top of the gasket, and then remove the nozzle from the gasket. Remove the gasket from the water inlet pipe, and then loosen the 7-mm bolt that tightens the wire holding the gasket to the outer tub lip. Take note of the position of the gasket, and then remove it and the wire from the lip of the outer tub.
Install the new gasket into the lip of the outer tub aligning the notch in the gasket with the arrow located on the top of the lip of the outer tub, and then secure it with the wire and the bolt. Do not over tighten the wire with the bolt. Allow a gap of about 1.25 inches between the ends of the wire. Over tightening the wire may tear the gasket.
Insert the nozzle into the gasket ensuring that the washer is placed on the outside and that the nozzle is aligned with the dent on the inside of the gasket. Insert the water inlet pipe into the gasket, and then put the gasket inside the drum.
Reinstall the front panel back into position on the hooks then secure it to the cabinet with the four Phillips-head screws.
Slide the toe panel up into the cabinet then secure it with the three Phillips-head screws.
Reconnect the wires to the control panel. Snap the control panel back into the cabinet, and then secure it with the screw at the recess of the drawer opening.
Slide the top panel back in place then secure its rear with the three 7mm hex-head screws to the cabinet. Reinstall the top cover and secure it the three Phillips-head screws.
