Sorry to read about your problem, I hope this helps you out.
This is the part number of the hinge 02200021 Try getting you parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful 3 Thumbs - Helpful 2 Thumbs - Somewhat Helpful 1 Thumb - Not Helpful
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
There is a possibility that the burner is partially blocked,make sure the oven is off and cool, take out the shelves, get a torch, a pin, a small piece of emery paper (or brillo pad) and a matchstick.
Inspect the burner at the back of the oven (look at the holes) remove any debris with the pin or match stick, use the emery paper/brillo to clean the igniter (this is a white stick with a piece of metal sticking out near the burner) very gently clean the metal part.
Try lighting it, if it makes no difference it's likely that your FSD (Flame Safeguard Device) is faulty and not allowing the correct amount of gas through.
It's a fiddly job looking at that so i would highly recommend a 'Gas Safe' engineer take a look at it for you.
