The port number will not go throgh and need my in coming call because my sister died this morring. And I sure would like to get my calls
MagicJack uses port 5060 and 5070 UDP. Here is how MagicJack works:
http://www.magicjack.com/how-it-works.html
Also check out this support page:
http://www.magicjack.com/faq/
Hope this helps.
Most likely your system has a firewall somewhere .
Could be the router. You need to log into the router and check TCP ports 5060 and 5061 are allowed in the firewall settings . ring your isp and ask them to help you get Voip incoming ports to work on your router for incoming Voip and tell them the device you are trying to use
