I-INC UniK Trio AXS 3G with Wifi 7.85" Touchscreen Quad Core Tablet Mach Speed 1.2 GHZ 16GB 2014 Release T-Mobile 3G Slim Folio Case [Bonus Stylus] - Hot Pink Logo
V
Veronica Green Posted on Jan 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trio Quad Core Tablet will not charge
Plugging charger up to trio quad core tablet. Getting an error symbol when it tries to charge
Frank Russell
Level 2:
Novelist:
  • Expert 86 Answers
  • Posted on Jan 03, 2015
Frank Russell
Expert
Level 2:
Novelist:
Answers
86
Questions
0
Helped
27451
Points
105
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
  • Janet Rabideau Apr 08, 2015
    Where do I go to check on warranty. It is the port on mine, it is loose you can see it move around in there and won't let it charge.
My tablet wifi will not turn on i already try to hard reset it
has it got an aeroplane mode in the settings that might be on ?
or a manual switch that might put it in aeroplane mode.
My tablet won't save to its SD card
Try another sd card to see if the problem lies with your original card or the tablet itself.
I charged my new trio 8x s 4G quad core tabletYesterday, Plugged it in To recharge it Last night And it won't recharge Help me
Interesting - possible that it is not low enough on charge for the charger to operate?
Is the charger working and connected properly to wall outlet?
Why I have to double click on the screen every time, and it's hard to scroll on the screen of My Trio Tablet?
This is an indication of limited RAM left, usually below 200MB. There are too many apps running in the background or an application consumes too much of the RAM. Use a Cleaner application to clear unnecessary cache which is normally the main culprit. ES Task Manager can do a pretty good job for this.
Ho do i take music and pictures off my trio axs 3G tablet because my screen is broke in the top half
connect it to your computer with usb cable and copy files to your computer it should ask you when connect it what you wanna do or you can use my computer or start menu to browse the tablet and select files to copy to the harddrive
My Trio tablet I lock it and don't know how to unlock it
YOU PUT YOUR PASSWORD IN OR YOU FORGOT IT ?OU MAY HAVE TO TOTALLY RESET ..USAUALLY PUSH VOLUME CONTROL AND ON BUTTON AT SAME TIME TO GET TO RESET MENU
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Ematic HD Quad Core will not charge
You have to replace its battery its damaged
Top I-INC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an I-INC Tablet and eReader Expert? Answer questions, earn points and help others
