Unplug and leave unplugged for 12 to 24 hours (i.e. ''overnight''). Do a search for a firmware update (not a ''regular'' data update). Download Firmware update and prepare as per instructions. Plug in Playstation, but don't try to ''load'' a game or anything. Perform the firmware update. If there are no firmware updates for it, attempt to install the same firmware as is current. You'll get a message that the firmware is up to date. Then exit the firmware installation, reboot the unit, and then try to load a game.
SOURCE: Playstation Update was interrupted. Now when PS3
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
Step 3:
Step 4: We recommending performing the safe mode
options in the following order until one of the options works for you.
If one of the options work, do not continue onto the other options.
Notice (Read Prior to Beginning the Software Upgrade)
The following events may interrupt the upgrade process and result in an inoperative unit.
1) DO NOT unplug the Power Cord during the software update procedure
2) Avoid loss or interruption of power during the software update procedure
3) DO NOT Press the power button on the unit during the software update procedure
In the event of software upgrade failure please contact TOSHIBA Customer Service at 1-800-631-3811
