Contributor
- Posted on Jan 02, 2015
Re: How to change parking brakes on 2003 dodge ram
Determine which type of emergency brakes your Dodge Ram will need. Emergency brakes typically function by activating the regular braking system on the driving wheels. The emergency brakes for the Dodge Ram have used rear disc brakes since 2001.
Release the parking brake pedal completely and raise your vehicle. Remove the tire and wheel with a socket wrench and disconnect the brake caliper from the caliper adapter. Slide the rotor from the axle shaft.
Install the new brake rotor onto the axle shaft and complete the installation by reversing the removal steps.
Tighten the wheel mounting nuts in the proper sequence with a torque wrench until the nuts are torqued to 47.5 foot/pounds Repeat the tightening sequence to torque the nuts to 95 foot/pounds.
5
Apply and release the park brake pedal to seat and adjust the parking brake cables. Road test the vehicle to ensure the vehicle's brake system is functioning.
6
Place tool C-3919 or the equivalent over the park brake shoes and use the star wheel adjuster to lower the park brake shoes until the lining just touches the jaws on the tool.
Read more : http://www.ehow.com/how_4521030_replace-emergency-brakes-dodge-ram.html
