Uniden DECT 6.0 Cordless Phone ID Logo
R
Robert Culp Posted on Dec 31, 2014
Cannot make or receive calls
Error codes h f4135 0219 5 b f4160 0620 5
2answers
My dish joey has a code 024 error how do I reset my joey
Please first refer the the table of contents of your product manual in order to find the section related to factory resetting. You can also call the product manufacturer and request the manual be emailed to you if you do not currently have it.
Thank you.
Zynga farmville
Customer care support service number +1-833-272----0777...........call them.[[[[[[[Customer care support service number +1-833-272----0777...........call them.]]]]]]]
how can i remove zynga poker error code RS1
how can i remove zynga poker error code RS1 zynga poker error code RS1 eror code rs1 i have the same problem,.
Fase7073nwo
Good Afternoon Friend, this is Z. Thank you for your question!
An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if this is the cause of the error code. Depending on the readings, the heater and/or wiring will possibly need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
Error code 55
Hi Ronnie Penley,
I understand that you are receiving an Error code 55. Typically the best way to try and clear this would be to reset the appliance for at least 3 minutes. You would do this by either unplugging the washer or cutting the power off at the circuit breaker. When you return the power, try and start another wash and if you are still receiving the error 55 code I would call the manufacturer for further help.
-Best Regards-
Error code 299001
Here's what Nintendo has to say about this code:
Error Code: 299001 Nintendo DSi Shop
There appears to be a temporary issue with the Nintendo DSi Shop. Please wait awhile and try your connection again later.
If you have waited several hours but are still receiving this error code, please call 1-800-255-3700 for assistance.
In short, there's nothing necessarily wrong with your DSi, but if you get it repeatedly I suggest you call that number.
1helpful
1helpful
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
1helpful
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
