Did you think to google sony kdl red light blinking 6 times??
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
SOURCE: 6 red light blinks-possible thermal fuse prob.
You need the location of the part that's stamped on the board near where it was soldered in. And you need a soldering tool to resolder the new part in and cut the excess wire with cutters so you're not to short out the circuit.
C-Dog
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
SOURCE: Problem with Sony Bravia 46" TV (Model
blow out fan in mother board tower mother is over heating and not geting enough of air leting the mane chips over heating makes computer stop so it doesnt catch fire.
SOURCE: Sony BRAVIA KDL-46V3000 Television goes black
This issue
is related to a power problem in as much as the TV turns off on it's
own. I think the TV has developed a power problem.
The problem is consistent with overheating on the power supply board of the TV.
The
power supply board of the TV has few capacitors and IC. If any of these
IC's gets short or become weak, it can cause the TV to turn off on it's
own.
When current passes from electric outlet to the power
supply board of TV. The current also goes to the weak/faulty part, then
the current stops or slow and the board overheats and TV shuts off on
it's own.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
This
is a common problem faced by many other users too. To solve this issue,
check the power supply board and read it with a meter and continuity
tester, in order to detect the faulty part and replace the faulty part
on the board which is short due to which power supply board.
Sony specifically uses GM1 Board. In other words, Sony power supply board is called "GM1 board"
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
You
can buy this part at any Fry's or Radioshack store or you can order
them online at vendors like "mcmelectronics.com"(look for electrolytic
capacitors). After replacing these capacitor (capacitors) most likely
the normal operation will be restored. Or you can buy a refurbished
complete GM1 power board from shopjimmy.com to save you some stress.
If
this task is too technical for you, you can call a family or friend who
has the ability to assist you (two heads are better than one).
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TV will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
