You don't need any software to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
SOURCE: No solution disk. Can I download it?
Follow this link to canon's website to download everything that came with your camera.
http://tinyurl.com/88a8kq
*if you have to reselect everything like camera powershot a series and then the model number your model number is all the way at the bottom*
After that is done select the OS from the drop down menu that you are currently using and start downloading anything you want. Everything on that site is what came on the 'disc'
