How to re set my Sony vpl cs 6 to factory setting
SOURCE: Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
SOURCE: Sony Data Projector VPL CX75.
This may or may not be the solution to your problem, but i'll let you know anyway. Input settings are only accessible when you have a signal going into the projector. This is because the input settings are for adjusting the signal, therefore if there is no signal there is nothing to adjust.
SOURCE: How to reset to factory default settings on projector sony VPL-DX126
here's the user manual of the prjector:
https://docs.sony.com/release/VPL-DX126_DX146_DW126.pdf
i've readed it and i guess you should push the reset bottom in the remote.
Testimonial: "First thank you for your response! I read that manual and it sad that if I forget my pass for web app to contact sony With reset on the remote you can only reset few things like projection of picture not things like I need I contacted Sony already i I have option to send my projector to UK :D or to put my projector on the internet for remote access from them"
