Question about Sony Network Walkman NWZ-S545 Digital Media Player
WALKMAN NWZ-S545 Immediately following charging with a 5 VDC-120 VAC Adapter-Cannot play thru USB: My car stereo shows "No Songs" when plugged from sony plug-jack to car USB; but plays songs when 3.5
Not tried soft reset. Tried recharge; upload, download, delete songs, changed cords. WALKMAN NWZ-S545 Immediately following charging with a 5 VDC-120 VAC Adapter-Cannot play thru USB: My car stereo shows "No Songs" when plugged from sony plug-jack to car USB; but plays songs when 3.5mm plug in from WM jack to car jack. Whatz the fix?
    Sergeant:
  • 399 Answers
Try changing the audio source/input on your car stereo to USB.
Posted on Dec 31, 2014
6ya staff
SOURCE:
How do I change the battery on the NWZ-S545 when theres not a compartment to open to change it?!
Use the USB cord that came with it and hook it up to either your computer or to a USB charger
Dec 30, 2011 | Sony Network Walkman NWZ-S545 Digital...
My mp3 is frozen on the screen when you first plug in your mp3 to a computer. If I reset it, will all my songs be deleted?
the reset will not affect your files ...only when you format it it affects your file ...If you need to format the memory do not try to do it from computer cause you might end up deleting the firmware ...look into the menu or in the manual cause there is a procedure for fast formatting from the device itself..
So ..if you only want to unfroze it ..you can reset without care ..cause the procedure is actually a soft reset ..which will practically reboot it and load the factory settings ..
Feb 15, 2011 | Sony Network Walkman NWZ-S545 Digital...
Se apago mi sony nwz s545 y oquiere prender como ago para restablecerlo
This worked on me: I just plugged the USB conection to my "Phillips DVD player with USB conections" insted of plugging it to my PC. So I just played a song on my DVD player and when I stopped the song, turned off the DVD player... I unplugged it from the USB port and !!!!! appeared again what I was waiting for so long: The welcome screen "Every moment has its music." plus the "Creating Library" And finally I said "THANKS GOD!"
*** I tried many ways to find a solution (pressed the RESET buttom, charged the battery... but nothing happened... my screen was totally black = OFF).
Well.. I hope this is helpfull for all of you.
Jan 04, 2011 | Sony Network Walkman NWZ-S545 Digital...
How to unlock the volume limit in Sony Walkman NWZ-s545
I'm just wondering, why don't you just download the MP3Gain. You can adjust the volume of all the songs to one db of your choosing. It's easier than trying to set up your mp3 player using the test mode, the result of which is usually the radio malfunction.
Sep 05, 2010 | Sony Network Walkman NWZ-S545 Digital...
My nwz-s545 is not working properly i have had it for about 4 months now and when i charge it it blinks rapidly and will not cut on properly. the start screen will pop up but it will just freeze and wont...
On the back of the unit, there should be a small reset button. Pushing and holding that button for about 5 - 10 seconds should reset the unit.
If that doesn't work, you may want to read WarMaiden.org's solution to getting the computer to recognize the Walkman...it may work for you.
May 14, 2010 | Sony Network Walkman NWZ-S545 Digital...
The mp3 nwz-s544 will not charge when plugged into computer. It used to but would randomly connect and disconnect now it will not charge at all and says that it is an unrecognized device in usb.
You can try resetting the unit. There should be a reset button on the back of the unit. To reset the unit, press and hold the reset button for about 5 seconds.
If the computer still won't connect to the Walkman, you can try the Walkman recognition solution posted on WarMaiden.org. This may solve your problem.
Feb 28, 2010 | Sony Network Walkman NWZ-S545 Digital...
My sony walkman won't turn on
Thank You DamonJones. Hitting reset on the back with a pin WORKED. My mp3 is back up and running with all songs
Feb 20, 2010 | Sony Network Walkman NWZ-S545 Digital...
Sony Network Walkman NWZ-S545 Digital Media Player Logo
180 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
