Need to change my password for belkin3d93-bought ipadair2 .works perfectly except connection to belkin at home(where everything at home works) because i cannot remember correct password. tried all co
Have belkins password on the machine- it does not work-either went back to apple store and they are sure it is my password problem how can i reset
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network. First, connect to Belkin's wireless network that you can scan. After you connect, try to go online It ll work...
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Check whether the SSID broadcast is enabled on the router. If it is already enabled then try changing the wireless channel on the router. for this you will need to open the set up page of the router. Click Here for more info about networking
admin usually gets u into the router for access WITHOUT a password. Set a new password or resetup your network with the disk that comes with your router.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
If you access your router, look at the wireless settings, you may need to change a setting to allow b + g connections, your laptop may have a 'b' adapter.
