Try this first, make sure all doors are locked. Insert door key in drivers side door lock and turn key left for 3-5 seconds then turn to the right with a little pressure. open door. Insert key in ignition and turn to on ONLY! wait at least 30 seconds, then turn key to start allow to idle for a few minutes. If problem persists, the remote is not functioning properly. contact a locksmith for reprogramming or replacement. A lock shop will be cheaper than the dealer! Hope this helps you!
SOURCE: 2002 VW Cabrio alarm problem:
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
SOURCE: 2002 VW Golf TDI open door light & alarm
check door switches remove 1 at a time and unplug it once you find the bad switch lights will go out
un plug 1 at a time
SOURCE: Can not disarm alarm on 2002 jeep grand cherokee
First, try to re-programme the RKE (Remote Keyless Entry) transmitters before searching for anything else. Assure that the batteries in the transmitters are in working condition and replace them if you are not sure. To pro-gramme the transmitters, perform the following:
Open the driver's door and let it be open throughout the programming process. Then, shift the mechanical door lock lever to the LOCK mode, turn the ignition key to the rUN mode. Within a period of twenty seconds, point a transmitter at the receiver dome and push the lock button for a period of five seconds at least. After the receiver has accepted the programming code the driver's door will unlock on its own. The first transmitter has been programmed, in the same extra transmitters up to four may be programmed in the same way, within twenty seconds.
If the alarm does not work
properly, you may have a faulty alarm module and may have to be replace and its common problems with and older model. the systems work like a security systems, if you arms your system with the remote you have to disarm it also with the remote in order for the engine to start and run. The logic in the PCM prevents the VTSS engine no-run feature from arming until the engine start; Its one of the security systems jeep has and if you ask for my opinion its junk. hope that help some..
SOURCE: Alarm haywire, can't override anti-theft system or turn on car
The Alarm on my Mercedes ML320 sounded every night, then it started doing it more often, Showed it to the dealer he says it's the 'Tow Sensor', that needs to be repaced. $700, down the drain. I have already started hating this car, it eats $500-600, every 6 months...
SOURCE: Was washing and waxing 1997
put key in door lock,unlock/hold key over windows will go down....then lock/hold key over,windows will go up,press and hold unlock button on remote for 30 secs,you have just reset the alarm/immobiliser.
Testimonial: "Also found out that locking and unlocking the trunk will reset the alarm function. Thank you."
