Removed filter and cleaned out around impeller.
Check each arm's holes. Lack of water can come from clogged or restricted holes in the arms. If the arms can be removed, check to see if obstruction inside the arms is present.
If you find obstruction, you want to remove it and also try to figure out where it comes from so it does not just clog up again.
If you can remove the arms, close the door and run the dishwasher long enough to hear whether water is gushing as it should or if there is very little water movement noise. Also make sure the machine actually fills properly to insure that the water line is not kinked.
Chances are that the pump could be bad. Search for a new pump on e-bay (where I found mine the cheapest) or do a google search for the part. Pumps are relatively quick to change out.
Worst case scenario is that you have a problem with the circuit board and it is cutting off the pump.
