Checked speaker cables
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
SOURCE: connecting TV and DVD for surround sound
HDMI is fantastic in that's the only thing you need to plug in to get what you want.
You'll need two of them however. Plug one end of the HDMI cord into the HDMI "OUT" on the dvd player and the other end of it to the receiver..labeled HDMI 'IN' Then, take the second cord and do that step with the receiver back to your big screen...HDMI OUT to IN.
Surround sound from TV sources only needs a L&R audio cable connected to the receiver input labled TV or MONITOR audio IN. Unless you'd like 5.1 dolby digital or DTS from the television that requires devices that you haven't mentioned owning. In that case you will be able to get Dolby ProLogic and Pro Logic II from stereo broad casted sources on your TV.
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Well there are two possible reasons. 1st- make sure that to do a factory reset on the amp. while it is on Press DVR/VCRat the same time press the power button (Standby) clear will show on the screen.system is now back to defaults try the video.
2nd If the video still not working check the TV out settings. Press Setup - Input Out put assign - Monitor Out- Make sure it's set to HDMI. and the resolutions is set to Through. if this setting is ok and you problem is not solved. it could be an issue with the board or your hdmi device it self.
Let me know?marc
