<span>Hi.<br /> <br />Sentry respects strong security standards. There is no simple way of hacking a safe if you loose the combo. If there was a simple way of opening a Sentry safe, Sentry would withdraw the model from the market.<br /> <br />When you own a Sentry safe you are supposed to register the combination in Sentry website. The combination will be held as encrypted data in Sentry server. After registration you get an user name and password that will allow recovering the combination.<br /> <br /></span><span>If you have already <a href="https://www.sentrysafe.com/CustomerCare/Store_Combination">registered</a> and need your combination now, <a href="https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination">you can recover your combination clicking here</a>.</span><br /><span><br />Most owners are not aware and do not register the combination.<br /> <br />If you have not registered the combination, then for security reasons you will be asked to send Sentry request your combination from the Customer Care team. The request must be accompained by a notarized letter stating you are the owner of the safe (form must be downloaded from website). The document can be obtained from any local Notary Public office.<br />You will also be required to pay Sentry $20, that is what Sentry will pay to verify with double check your identity.<br /> <br /></span><span><a href="https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination#">Page is the same published before, at the bottom the button to open Notary public form template.</a></span><br /><span><br />I know that the procedure is annoying, but that is the only way to get a lost combo. Sentry care to protect owners property and safety and security concerns impose use of this procedure.<br /> <br />Other useful links:<br /> <br /></span><span><a href="https://www.sentrysafe.com/ContactUs/Call_Or_Email_Us">Call or Email Sentry</a></span><br /><span><br />International websites:<br /> <br /></span><span><ul><li><a href="http://www.sentrysafe.co.uk/">United Kingdom</a></li><li><a href="http://www.sentryjp.com/">Japan</a></li></ul></span><span><br />Here US customer care number: 800-828-1438.<br /><br />Ginko.<br /></span>
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
If you need your lost combination, you must send in a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
If you need your combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Locksmiths agree the factory code is burnt into memory and can not be erased. When you buy a sentry safe you have to set a user code to give out as that code can be changed. program instructions
u can request a lost combo from the sentrysafe.com u gotta get a it noteiatized and send it in to them the details are listed on the webpage i hope this helps u
