I can to do anything because only I can read:
boot failture
Reboot and select proper boot device
or insert boot media in selected boot device
press any key when ready
You need to obtain a recovery CD for your operating system. It will give you some recovery options which may work. If not you will probably have to reload the operating system. You might be lucky and there is a hidden recovery partition to set the machine back to factory state. Google your machine for recovery partition option.
This can happen if you have non-bootable media in the default boot device (i.e., you have a CD in the CD/DVD drive and that drive is listed as the default boot device in your system's BIOS). More often (on newer systems), a failed hard drive will also produce this message.
If you have bootable media (the Windows install CD is one example), you should try to boot to it and see if you can read your hard drive.
The proper boot device is your hard drive, when you boot hit F2 while it is booting up and it will bring up the screen to change boot devices select the hard drive and save the settings and this should work if it dont it is possible that your hard drive has bit the dust.
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Listed below is link to HP drivers page for M270. The recovery Windows Media Center CD is no longer availabe for purchase. If you have a license copy of Windows XP you can install then download remaing drivers from link listed below:
When i turn on of my pc. then bios screen msg reboot and select proper boot device or insert boot media in the selected boot device. How to solve of this problem. pls .............solve tips for give me.
