No spark,new plug,gas,fuel line,cleaned carb, do I need to remove stater/flywheel and see if a magnet or something is missing?
Clean out the float bowl as well clean out the fuel jet in the bolt that holds the bowl on. There usually are very small holes in this jet and if you can't see or blow through them you have to clean this out. Will not run if this is plugged. You can blow this out with an air com presser or a very small wire to push through it. Don't force anything through this hole or you could damage it. If it will start when you put a spoon full of gas in the spark plug hole and replace the plug and stalls in a few seconds it's usually a dirty carb or dirty jet. You can buy a cleanser as well to spray if needed.
If the key in the flywheel is broken, it will be sparking at the wrong time, if this is electronic ignition. If this engine has points then it will not spark at all if the flywheel key is broken. If this is electronic ignition and there is no spark, then the ignition module is bad, or something is shorting the enging kill wire coming out of the coil.
