SOURCE: fsx multiplayer problem
When that message is displayed when logging onto anything means that there is another PC that is already logged into using the user name and password you just entered.
If you have more than one PC make sure you are not logged in on your other PC. If this is not the case someone is possibly using your details. You can also go to gamespy's website to the support section. You should be able to contact them and seek help on what to do about it.
Thank you for choosing Fixya!
SOURCE: MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
SOURCE: no where to plug in
The 3D pro has a game port connection. The older Sound cards came with game port connectors. Yes it would work for MSFS if you had that connection on your computer. Best bet is to go pick up an under $20 Saitek at your local Walmart/BestBuy/OfficeDepot. They are USB and work with MSFS just fine.
SOURCE: My Microsoft Flight Simulator 2000
Hi start off by re-installing the whole game. uninstall the game properly and then run it again from the disc, also make sure the cd's surface is clean, if the problem remain after that let me know and if you get any kind of error messages let me know also.
a possible workaround for the disc verification would be to bypass it.
