Press Mode until the time/date screen shows on watch face. Hold Set for a second or two and quickly press Mode. The Hour should begin flashing, meaning you can now adjust it. Press the Adj button repeatedly to scroll through each hour and once it is correct, press Mode again to move onto next item. You can adjust Hour, then Minutes, Month, Date, Day of the week, and Seconds. If you wait too long you'll have to start again at Set and go through each item by pressing Mode. Press Set after you've adjusted the final item you want, or stop pressing buttons and the reset will eventually time out and flashing will stop.
1- Press and hold RESET and LIGHT together, be patient
2- With ST/STP change the digit blinking
3- With MODE choose hr, min, date....
4- Once done press RESET.
NOTE: To set T2, display T2 before doing the above steps.
Hold the mode button, until the times start flashing, you might do this wrong and activate stopwatch. Then you press mode again and it will show the time you want to change. Press the start/stop button to toggle through seconds, minutes and hours. And months and days
Press and hold "MODE". Press MODE 2 times (after the first time, the
alarm time flashes, after the 2nd time, the second flashes). Press ADJ
to change seconds. Press ST/STP to switch from seconds to minute. Press
ADJ to change minutes. Then press ADJ to change hours. Press MODE when
done.
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
