Https://esupport.sony.com/US/p/model-home.pl?mdl=SVL24127CXB&template_id=1®ion_id=1&tab=manuals#/manualsTab
MAYBE SAME HELP.
Testimonial: "I very much appreciate your reply Lars. However I've been through everything that Sony has online and/or on my computer and cannot find anything relating to working on the inside of the computer (including nothing about breaking it down for service). The last person I talked to @ Sony told me straight out that the manuals for that type of service is not given to\or made available to the consumer. Hence my effort to find someone with some experience with this machine. Thanks again for taking the time to reply. Lonnie"
SOURCE: install dvd drive
Refer to the picture below: The CD drive should have 3 jumper pins labeled Master (MA), Slave(SL) and Cable Select (CL) at the back near the interface ribbon cable. In this picture the green jumper is in the Master position. To make it a Slave drive, you need to remove the jumper and place it in the middle pair called SL. You may have to remove the CD drive if you can't access it while in the system. When you put in the new DVD drive ensure that its' jumper is in the Master positon. The drives will not work if both have jumpers in the same position. Get back to me if you need more help.
SOURCE: I need help! I'm
here is what you will need to complete this project:
Installing Your Harddrive Step1
Open up your case after backing up any important files and locating and installing any software that came with the hard drive. Check to make sure that your computer supports SATA or that you have a SATA PCI card installed.
Step2Look for the smaller connector on the SATA cable and connect it to the SATA connector located on the motherboard or controller card. If you already have another SATA drive, simply follow its cable to the motherboard or card to see where this one will attach.
Step3Grab the larger end of the SATA cable and connect it to the back of the SATA drive itself. You will also need to attach the legacy 4-pin connector or SATA power cable to power your drive. At this point, check to see that both the smaller and larger end of the SATA cable and the power cable are securely connected and proceed.
Step4Choose an available drive bay and insert the hard drive into it, mounting it in place with the four screws provided. Make sure to follow the directions that came with your drive and place the screws in the designated holes to secure proper grounding.
Step5Ensure that all cables are properly attached and replace the tower or desktop case cover. After doing this, you're all set to reconnect the power cord and turn on your computer.
Formatting and Partitioning
Step1Boot from your Windows CD. If this is the only hard drive present, you'll be shown a series of instructions and should simply follow along.
Step2Select "Control Panel" then "Performance and Maintenance" and finally "Administrative Tools" for an additional hard drive. Then click the "Computer Management option and choose "Disk Management." Simply right-click the drive to partition and format it.
Step3Follow the steps displayed. Windows will guide you through the rest of the process.
Now for your dvd drive----
1.Shut down the system, unplug the power cord and remove the side panel or panels from the case.
Ensure that the new DVD-ROM drive is set to be "Slave" or "Master," depending on if it is a replacement or an additional drive. 3
2.Locate the empty drive bay for the new DVD-ROM drive, and remove the drive bay covering. 4
Insert the new DVD-ROM drive into the empty bay and secure with screws or other attaching device provided by the manufacturer. 5
3.Connect the open connector on the ribbon cable (red stripe towards power cable) to the new DVD-ROM drive and connect the power supply cable (plastic four connector plug from power supply)to the drive. 6
Replace the side panel or panels, plug in the power cord and turn the system on.
Install your dvd software bundle and get to work.
These are actually two things you will want to do at once while the computer is open , but i would do them one at a time in case you have problems you will know what to blame. You can leave the cover off while operating the computer so that you can test it after the hard drive instrall and before the dvd install.
SOURCE: sony pcv-rx860 dvd drive will not open to remove cd-
Hi, if you look at the front of your cd drive you will see a little hole. This is an eject mechanism. If you insert a paperclip in this whole you should be able to manually push the drive open. Once it is open it may release what ever is causing the drive to jam.
I hope this helps.
SOURCE: i can't burn anything with my DVD/CD-ROM but it reads dvds and cds
first reinstall the operating system and then you use either nero 6 or NTI CD? DVD maker
SOURCE: Bad DVD/CD Drive
ok to be clear you want to change the dvd cd rom drive corrct? here how to first thing first take of both sides of the computer (im telling how to for 99'9% of comuters not specifcly yours) there will be 2 screws on each side of the drive take these out now 2 ways to remove from here it will 1 slide out the front or 2 it will be stuck from the from becouse the farsade is holding it in (remember to take both cables out the back of the dvd rom drive) if its 2 then then there will be 2 ways to go from here if there is a lot of space at the back then take it out there if the box with wires is in the way there are 4 screws holing it on take these out and move but dont take all the wires out of everywhere the box of wires (psu) then take out old dvd rom drive and replace it put the psu back in and screw it in then screw in the dvd rom and wire it back up your done turn on the computer it will go to windows and install new device if howver there is not a lot of room and removing the psu wont help then you need to remove the farsade at the from (front cover) ther eis normaly 6 clips at the side push these to remove the farsade and pull ou the dvd rom and replace it that way hope this helps i can provide further info if needed just ask
you might have to physically unplug the leads for this
cd/dvd then plug them back this should activate the found new hardware
wizard or you might
have to uninstall then restart your computer then reinstall your DVD/CD then
reinstall the driver for this device
if your computer came with
a motherboard disk the drivers could be on it click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
http://download.cnet.com/sun-cd-dvd-burner/3000-2646_4-10308060.html
Sun CD/DVD
Burner can back up data on CDs and DVDs, store large media files, and compile
music CDs. It can burn and save whole ISO files, as well as create multisession
CDs and erase rewritable CDs. Sun CD/DVD Burner supports almost all kinds of
driver types including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM
(SCSI, IDE, EIDE, and USB). The program also supports the ability to drag and
drop. Version 3.10 may include unspecified updates, enhancements, and bug
fixes.
What
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
NOTE: If the Roxio DirectCD software is running, eject the CD using the Roxio DirectCD software.
NOTE: If the drive tray ejects in BIOS, but not in the operating system, reinstall the CD, DVD drive.
