DeLonghi DE500P Dehumidifier Logo
Posted on Jul 06, 2009
My 3-month old Delonghi 50 dehumidifier is leaking
I have tried to troubleshoot by removing the tray that is supposed to collect the water. I notice their is a hose behind the tray that is facing up with water in it but can't be sure the water is flowing properly in to the catch tray/drawer. Any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
938
Points
Anonymous
Level 1:
New Friend:
  • Posted on Aug 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
938
Points
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Delonghi dehumidifier DE500 P leaking water
The hose is supposed to be in the tank. Someone emptied the tank and forgot to put the hose back.
Hi! My home dry 660 collects water but also has started leaking onto carpet? Is this a big fix? It is probably about 10years old!
not that big of a job ! it just needs a good cleaning out, start by unhooking power and then remove outer case , look inside at area that has lots of fins !! fine aluminum ones !! there should be a water tray just below the fins ! im betting this is well garb'd up with yuk!! take a 50/50 water bleach solution (gloves would be a good idea too) and work some f this around in the tray till it loosens up , remove with old towels or rags (throw em away) and find the drain hole in the tray that allows the water to drain into collection pan and poke down it with the end of a old pencil to clean it out as well (don't use metal) don't forget to clean your fan blades off too before reinstalling cover and leveling unit before reconnection power
Dehumidifier leaking
I have a duracraft DD-TEC16E I have had this for 12 months and has been working perfectly until today , I have noticed the water is not all collecting in the tank it's leaking on the floor . Any possible solution please?
1helpful
Two years old Delonghi DE400 doesn't collect water, everything looks fine and running (no water but smell in basement).
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Delonghi DH400p dehumidifier running but not collecting any water ? Humidity is 68 set to 50???
Hey, I had the same thing with mine.
First, try cleaning out your filter if you haven't already. It gets angry if it can't get any air.
If not, I don't know how brave you are, but I ripped mine apart to fix the problem. I took off the panel with the filter (5 screws) and you can see a collection tray with another little collection gutter under that. Both of mine were filled with junk, mostly dust that had gotten wet to make this awesome disgusting sludge. If you can get at it from there, try to clean the sludge out of the collection tray and the little gutter. I ended up taking my whole unit apart so I can get the collection tray out (dumb design, you have to take apart the whole dang casing to get at two screws that hold the collection tray in).
1helpful
2answers
Delonghi dehumidifier cf05m does not collect any water, why?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
5helpful
Moisture not collected
low on freon is the compressor running?
2helpful
Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
