Be sure you re-activate the handwheel. (You probably de-activated it to use the bobbin winder.) Consult your owner's manual.
Cindy's advice is good. Your bobbin winder may have the latch in the center of the spindle stuck, Inspect it to see if it protrudes when the bobbin is not on it. These can be bent or need lubrication.
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
