Televison & Video Logo
n
naste Posted on Dec 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Koks kodas televizoriui philips ir kaip nustatyti
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Dec 22, 2014
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007512
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
I have just bought a brand new remote for my Phillips 42 inch LCD tv from a reputable phillips website as the old one was not working (I recently bought it from my mate and his kid had eaten the on button...
Sounds like the IR sensor in the TV may be faulty, since you have now tried a couple remotes. Make sure nothing is on the IR sensor like tape, plastic, etc. IR sensor repairs are a fairly cheap and easy repair that can be done at your local tv repair shop. If you are still in warranty you can call Philips and tell them that you tried 2 remotes (1 brand new) on the TV and neither work. They should offer you a repair option. If you have any questions regarding your Philips warranty let me know.
3answers
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
Our Philips remote lost its signal to the TV. Dont have the instruction to look up code or how to progam it
dkellogg246, Try the philips website to see if u can download the instruction book or check with local repair shop to see if it even emits any infrared light out of the IR emitter diode!! How many times has it hit the hardwood floor? could be the battery contacts are in bad shape. I'm lucky I have what is known as a hand held IR scope to test output of remotes. But they cost 20 times more than a remote. Let me know what u find out. Kodak used to sell a "IR light sensitive card" detector that would glow pink when IR light hit it. But this "business card" size sheet of detector paper cost $40.00. Good luck! Hope this helped.
lmistyrel @aol.com
Kurent patition su programa magick patition 8 ismete lenetele ir buvo paroditos kelios particijos buvo pasirinkta ne pagrindine particija ir restartaau kompiuteri ir nebeuzsikrauna vindausai raso kad...
Parsisiuskite Hiren's Boot CD (naujausia versija), irasykite i CD (Burn ISO funkcija), ikraukite sistema is CD, pasirinkite Start BootCD -> Partition Tools -> Acronis Disk Director. Nustatykite Manual Mode -> paspauskite desini peles klavisa ant reikiamos particijos -> Ieje i Advanced meniupasirinkite Set Primary ir Set Active (paspaudus pasirinkima meniu uzsidaro). Prie norimos particijos turi pasirodyti "Pri,Act.". Bandykite ikrauti Windows. Jei nepavyks, tai ikraukite sistema is CD, pasirinkite Start BootCD -> MBR Tools -> Partition Table Doctor. Pasileidus programai paspauskite F7 savo klaviaturoje -> paspauskite YES -> Paspauskite OK. Paspauskite F8 -> Paspauskite OK. Paspauskite F3 -> Paspauskite Auto -> Paspauskite OK. Bandykite ikrauti.
I have a 42 inch philips lcd and the remote does not function the tv i changed batteries and even had customer care send a new remote still does not work
either the remote or the IR receiver on the tv is not functionin try a diffrent brand of remote if still the same problem its the IR receicer on your tv
105helpful
7answers
Having problems changing channels with philips HDR312
Hello, The IR cable has a purple color at the end of the connection.
On the back of the Tivo, It should be marked IR.
Looks like a headphone jack type.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
