Heating & Cooling Logo
r
ronald Posted on Dec 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor attempt to start an make buss sound ,do it need bareing
Oil bareing ,it to turn when no power is on.
Scott Corey-reid
Level 2:
Champion:
  • Expert 305 Answers
  • Posted on Dec 31, 2014
Scott Corey-reid
Expert
Level 2:
Champion:
Answers
305
Questions
0
Helped
154264
Points
334
High pitched sound is the bearings, if its a buzzing sound and motor doesn't come on, run capacitor may be shot
1helpful
2005 sebring died while driving barely no oil replaced oil and now wont start
Sounds like you damaged the engine by running it without oil. Sorry but you probably need a new engine.
Quincy 7.5 compressor motor itself sounds like
if the motor is humming, you probably have a weak starting capacitor
3answers
My Black bull 4 gallon 5.0 CFM 2 HP air compressor will not start. Regardless of whether the on or off position is selected, all I get is a humming sound for about 2 seconds, then it goes silent. After a...
I need the diaphram in the On/Off pressure switch on a Black Bull- 4 Gal., 2 HP, 5.0 cfm @ 90 PSI 120 v /13.8 amp . Batch # 0911. These are the only # I can find
I have a 1999 Dodge Avenger V6 and the vehicle stopped running yesterday about 2-21/2 blocks from my house. When attempt to restart would not start, tried starting and sounded like it was going to a couple...
Jenifer, it sounds like the oil lines from the oil pump are clogged or the pump itself is defective. Please do not run the engine until you get it checked out. If the oil pump in the bottom pan is not pushing oil to the top of the engine the valves and cams are not being lubricated and will burn up...Bue, Bye engine!
Troy-bilt gas powered blower was running at full speed and started smoking and quit running. found oil on engine. Changed plug and determined it is firing. Do not know what compression should be but it...
If it's a two stroke and ran it with straight gas you would need a rebuild, then it's up to you to see the value of your blower and see if it is worth rebuilding..
2answers
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
2004 ACCORD WONT START, BATTERY CHANGED AND STILL
the oil may be frozen? the bussing could be the noise that the starter motor makes when it either has no voltage or is not strong enough to turn the engine... keep the engine warm and change the oil, it could be seized and might take alot more work tho
My car will not turn over. Some times it start and sometime it won't. I have power to everything.
There are several things you can check:
Distributor cap and sparks - check for moisture.
Accelerator manifold (the thing on the top of the engine which opens to mix oxygen with the fuel) - oil any hinges and clear any water/debris.
Fuel - I know it sounds silly, but it has happened to people.
Starter motor - check connections.
Fuses - Check main fuse box for starter and other electrical systems' fuses; are they broken?
Is there a clinking sound from the engine?
Does the starter motor turn?
Attempting to start the engine too many times may result in the engine flooding with fuel, preventing enough air from being able to mix, thus preventing ignition.
You may need to bleed the engine of fuel.
Top Heating & Cooling Experts
Paul Carew
john h
