Consulting the instruction manual and searching for online help.
SOURCE: Zanussi electric oven ZBM 762X How do I trun the oven to manual?
If it is an anologue timer then rotate the knob until you see a hand symbol in the window, this brings it off auto.
If it is a digital timer then you need to press two or more buttons at the same time to get it off auto and back onto manual.
SOURCE: oven connection
I have tried to locate electrical information on your oven from here in the USA. I was not able to locate the electrical requirements for your Zanussi ZOD 330X. If it is typical voltage for ovens like ours in the USA I would say no and that the power should be 240 volts and 50 ampere breaker. But to be sure you should locate a local supplier for your model and ask them first. This will prevent any incorrect answers from someone that is not familiar with your local requirements. Thank You, Sea Breeze
SOURCE: How do I turn oven off with the oven programmer on
TURN ON THE OVEN AND THEN UNPLUG IT WHILE IT IS ON THEN WAIT FOR 10 MIN AND TURN IT BACK ON AND IT SHOULD HAVE A BLANK PROGRAMMER .
SOURCE: Need English user guide for Zanussi zob 662 x
zanussi built in single oven outer glass door has just exploded any similar problems or reasons for this
SOURCE: I broke the glass outside on the door of my
In my experience of repairing ovens, it is usually possible to replace glass without going to the expense of replacing whole panel.
Check with the manufacture.
Hop this helps.
