Televison & Video Logo
G
Gary Shugart Posted on Dec 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get my dvd player to play on my 60 inch vizio led.
twowheelin
Level 2:
Habit-Forming:
  • Expert 166 Answers
  • Posted on Dec 22, 2014
twowheelin
Expert
Level 2:
Habit-Forming:
Answers
166
Questions
0
Helped
74794
Points
414
Connect the DVD player to the Visio with an HDMI cable into 'Input 1'. Use the 'Input' button on the remote to select the correct input. If Input 1 is used, try another input.
Vizio intermittent backlight
You have to check the power supply of the tv. Normally led TVs power suppy is integrated with the led driver. If the led driver is faulty then this type of problems can occur.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
The vizio amp speaker plugged into my tv and bluray player stopped outputting sound when watching a dvd and now only blinks in a set of light at the bottom. What does this mean and how can I fix it?
TV sound bar problem - Audio - Audio - Tom's Guide
www.tomsguide.com/answers/id-1991267/sound-bar-problem.html
Jan 23, 2014 - I recently purchased a Vizio E Series Razor LED 60" tv for my home, and ... The TV plays sound with built in speakers fine, ... on the source playingthrough the tv, if via hdmi, the soundbar would ... Alright I plugged it in but still nosound. ... the tv hooked up yet but my bluray player runs off HDMI and my xbox ...
No Sound Thru Speakers (only sound thru TV) - VUDU Forums
https://forum.vudu.com/showthread.php?...No-Sound...Speakers...sound...
Jun 18, 2011 - 10 posts - ‎8 authors
Just purchased and connected an LG wireless internet-ready TV to a receiver, a DirectTV HD DVR satellite box, and surround sound speakers. ... Cable, Blueray player, and others internet services, like Cinemanow provide ... because i have a Vizio Soundbar 210WS model, and i have to go into the TV ...
2answers
How do i fix the line on my vizio 60 inch smart tv?
Good day,
Eh, lines are usually due to the screen being hit and an electrical open appearing in the panel. Sometimes, if the device has been knocked or fallen, the panels connector may have come loose. I would open the TV and look for the video board to see if the connections are still good. Give them a wiggle and see if the line clears.
BE CAREFUL OF HIGH VOLTAGES INSIDE THE BACK !!!
Good luck...
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Why willmy blu-ray player home theater play surround audio but no video?
tried to replace the cable wire then tried to hooked up with other component input of the tv unit just to isolate where the problem came from.by the way did you tried to play other dvd disc does the same problem?.
Am trying to connect my Toshiba SDK1000 DVD player to my new Vizio 42" LED TV using HDMI. The DVD is playing as I can see the chapter numbers progressing, but "no signal" error on the TV. I...
Try another hdmi cable they are sometimes faulty out of the box. if the tv has more than on hdmi input try them with the spare cable.
Horozontal balck line across the middle of the screen
also check the dvd player set up menue some times you have to choose wich outlet your using like the rgb cables, s cable etc...
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
