I have looked on the player and tried to find maker while playing. I have looked up the info that comes up in player. It says InfoGation version 11.95 (build:2213.1453)copyright(C)1997-2011. licenced from Navteq and Navigon 1997-2007 (The free type project at www.freetype.org
SOURCE: 2005 navteq maps update
The map update is available from Panasonc for $150, it is advertised for $300. But when you call to order it they will tell you it's $150, and it with come with a disk and SD Card. Just Follow the instructions to do the update, this update will also apply to the iPod video problem too. The number is 1-800-405-0652 and tell them you need to purchase CA-MAHD08U.
SOURCE: I can't install the odyssey
I just downloaded and installed it from this location ..and it worked..
http://infogation.com/download/index.html
I used windows Xp ..without problems..and all I have been asked was to install active-sync program for to continue the program .
Here is the Active sync in case you will need too
http://www.softpedia.com/dyn-postdownload.php?p=18828&t=4&i=1
Make sure that you are logged as administrator when you are making the installing procedure..cause otherwise will not let you install After installing you will need to connect your device ..and be detected (using Active Sync ) for the program to work further..
