A camera store or electronics store will likely have the correct cable. It's most likely a "mini usb" connector. If there's a Best Buy near you, they should have it.
The manual calls it the USB Cable USB-3. DONT MIX THIS UP WITH USB3 cable. I Think, but I'm not 100% sure they mean a normal USB cable with a mini connector. To be 100% sure check the wiki page and look if it is the second from the left. It is a normal USB2 mini connector, you can buy in almost every electronics shop. Some manufacturers did use other cables, but this looks just a normal mini connector.
The Z6 uses MMC and SD cards. If you look carefully at your 8GB card, you'll see that it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The Z6 is limited to cards 2GB and smaller.
The Z6 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
e bahttp://cgi.ebay.com/NEW-KONICA-MINOLTA-Z6-BATTERY-COVER-SILVER-OR-BLACK_W0QQitemZ320433162573QQcmdZViewItemQQptZDigital_Camera_Accessories?hash=item4a9b4e094dy -24.99 at this site-
