Sony KS 50R200A Replacement Rear projection TV Lamp XL-5100 / 93087600 Logo
H
Hugh Moore Posted on Dec 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to replace my lamp and it won't lock in. Please help.
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on Aug 23, 2016
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197630
Points
977
Maybe your new housing is not fit for the projector
use the new bulb (lamp)
use your old housing ,
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
2answers
Fix vapor lock
Hi, This sounds like the fuel pump needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
1998 buick lasabre here's what happened I put the
Tray fish-hook size 5 or 7 bent the nose 45 degrees and try to pull it out .
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
1helpful
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
3answers
My panasonic TH42PX60U won't power up. No red light flashing. Completely dead. I tried unpluging and using different power outlets. Still nothing. Any help?
1. Check all cable and input connections are secure & all are tightly connected.
2.Check power cords and also power outlet , if possible try to unplug and reconnect . A replacement of power cable or use another power outlet is another good option.
3. If you are sure that power is reaching your TV(check it out with a test lamp that both neutral & ground or earthing is functioning, i.e. the test lamp glows) then probably the power board needs replacement.
2helpful
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
1helpful
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
The patio lamp will not light - have replaced propane tank but gas not getting to ignitor
It's not the ignitor that you need to worry about, it's the pilot assembly (which may need cleaning) or the lamp's gas regulator.But, since you just replaced the tank, let's try something else first.
Turn the gas tank's valve OFF and disconnect the hose from the tank.
Wait 5 minutes and reconnect the hose to the tank.
Open the tank's gas valve VERY, VERY SLOWLY (Slow motion, slow).
Once the valve is fully open, try lighting the lamp again. IT may take a few clicks of the ignitor, so be patient. If the pilot lights and holds, you've solved the problem. Remember to always open the tank valve Very, Very Slowly.
If the above didn't solve the r, it may very well be tat the pilot is clogged and needs to be cleaned. Use canned compressed air with a straw nozzle (like you clean your computer with) to blow out the tip of the pilot and any other debris that you see. If that doesn't do the trick, you will need to replace the lamp's Hose/Regulator Assembly, as your is locked up. You can use a grill Hose/Regulator Assembly, which runs about $30.00 at hardware stores & home centers that sell gas grills and accessories.
I hope this helped you troubleshoot & solve the problem. Please let me know. Thanks.
2answers
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 • Ovens
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
