How do I change the batteries on Oracode 660K?
On the oracode 660, on the outside bottom there's a star screw. Remove the screw and pull down on the black battery holder. Replace the 3 AA batteries and re insert the holder and tighten screw.
There should be a way to remove the inside cover to replace the battery , pretty sure its a 9 volt .
you may have to press in the retainer on the lever to remove it and then the cover plate should have a spot thats visible to use a small screwdriver to pop off the inside plate giveing you access to the battery compartment
Open Power Options by clicking the Start button, clicking Control Panel, clicking System and Security, and then clicking Power Options.
On the Select a power plan page, next to the plan you want to change, click Change plan settings.
On the Change settings for the plan page, click Change advanced power settings.
On the Advanced settings tab, expand Battery, expand Low battery level, Reserve battery level, and Critical battery level. Change the percentage of battery remaining that you want for each level, and then click OK.
