Vent blower comes on but will burners do not then the unit shuts down and the led light flashs 2 times
You didn't provide very much information, but I will try to help you. Here are some possibilities.
1. The pressure switch may not be closing, or is stuck closed all the time.
2. If this furnace has a hot surface ignitor, it may be faulty or not getting voltage.
3. If this furnace has spark ignition, the module could be faulty or the ignitor may not be positioned correctly.
4. The gas valve may be faulty, turned off, or may not have gas pressure to the valve.
There may be other issues, but I tried to cover the most likely causes. I hope this helps!
