I brought this dishwasher second hand, no model or product number only these details on the side typ e gs-0073 then 646-087-031 lp-0 then enr 606.380.903 then f.nr 097525720 then (m) 350/100w
Please, follow this link:
http://www.manualslib.com/manual/541167/Aeg-Favorit-625-I.html
Dado
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
SOURCE: Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
SOURCE: aeg favorit 86070 vi fully integrated dishwasher
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
