Question about Microsoft Windows XP Professional
How to remove administrator password - Microsoft Windows XP Professional
    Genius:
  • Microsoft Master
  • 2,910 Answers
Login to change password ,delete or change old password and logout, If others use the computer not a safe thing to do if no administrator password.
Posted on Dec 20, 2014
Tip
How to Recover Windows 7 Administrator Password
Microsoft Windows 7 is the latest version of Microsoft Windows operating system. Compare to its predecessor Windows XP and Vista, Windows 7 is more powerful and more secure. Unlike Windows XP, Windows 7 adopted a new password protection system that we can't use the hidden administrator account by default. The problem is that when Windows 7 administrator password lost, we can no longer recover our lost password by using the hidden administrator account. Therefore, how to recover the Windows 7 Admin password if we lost or forgot it?
Don't worry, here are two methods for Windows 7 administrator password recovery:
Method one: Use another Windows 7 administrator account
If you had created more than one administrator account on your Windows 7 computer and you can remember the others admin password, you are lucky. In such a case, you can change one of the administrator accounts' password if you login with another administrator account. What you need to do is just following these 3 easy steps:
Step 1: Click Start -> Control Panel -> Add or remove user accounts
Step 2: Choose the locked administrator account.
Step 3: Click Change the password or Remove the password. And then you can change or remove the lost or forgotten password.
Please note: If you select this method, the locked Windows 7 administrator account will lose all EFS-encrypted files, personal certificates, and stored passwords for Web sites or network resources.
However, if the locked account is the unique administrator account on your Windows 7 computer, you can try the method below.
Method two: Use third party Windows password recovery software
There is plenty of software which is used to recover Windows password available online. You can choose one of them to create a Windows password recovery disk and use the disk to recover Win 7 Admin password. I recommend Windows Login Recovery. Then you can follow these 4 easy steps:
Step 1: Download the software and install it on another computer which has a CD/DVD writer.
Step 2: Run the software and burn the ISO image file into a blank CD/DVD.
Step 3: Recover Windows 7 administrator password with nearly burned password recovery disk.
Step 4: Reboot your locked computer without a password required.
Now you can regain access your Windows 7 operating system and create a new administrator password. The best thing of using this method is that you shouldn't lose any data on your computer. Furthermore, If you can't find a computer which has a CD/DVD writer or the locked computer have no a CD-ROM, You can burn the ISO image file into a USB flash drive and use the USB flash drive to recover your Windows 7 administrator password.
Try these two methods the next time you lose or forget your Windows 7 administrator password, which you do not need to reinstall Windows system for getting back to Windows by removing lost or forgotten password.
on Jun 02, 2010 | Computers & Internet
How can I remove the administrator password of Windows 7?
When you are under account settings, go to administration settings.You have the opportunity to change administration password. If you leave it blank, you won't need a password.
Jun 07, 2012 | Computers & Internet
How to remove bios administrator password for hp elitebook 6930p notebook pls help me
Actually, if you want to remove BIOS password on HP laptop or PC, there is an effective tool Spare Key available for you. It is provided by HP Corporation. At the same time, if you prepare to remove HP administrator password, you can have a try to use Windows Password Genius. Choose appropriate version based on your computer operating system, Windows Password Genius Standard/Professional/Advanced.
Dec 08, 2010 | HP EliteBook 6930p Notebook PC
How can remove the admin password on my Dell D600 laptop
f you can already login to this computer and you have administrator's rights, then you do not need the administrator's password. You can go to the Control Panel - User Accounts to set up other Users or change the password on the various Users as well as the administrator.
If you need the administrator's password to set up a new user then there is a way to remove the administrator password.
You need to download Hiren's utilities and make a boot CD with this utility. You most likely need to do this from another computer.
For details on how to remove the administrator password please click on this link :-
http://www.fixya.com/support/r4335021-remove_xp_vista_password
Dec 05, 2010 | Dell (04U621) for Latitude D600, Inspiron...
IBM Thinkpad T21 2647 8AU remove Administrative password
to remove the administrative password follow this link for all about removing admi password its free check it
http://www.kellys-korner-xp.com/win_xp_passwords.htm
then for bios password try to remove the cmos battry for while then put it back for some systems the password may not go off. in that case, the password is stored in a chip the 24co2 ic which i can not locate the actual position. thank u
n plz tell me the extend uv gone if this helps.
bye
May 26, 2008 | IBM ThinkPad T43 Notebook
thing to do in log in box press ctrl+alt+del then et the user name type administrator leave the password blank
Mar 23, 2008 | IBM ThinkPad T20 2647 Notebook
Forget administrator password
this is how you remove the password go to start ,control panel on the right hand side double click that and go to user account click on the icon computer administrator and that will open to a new window and you will see remove password you got to type in your current password and then go remove
Sep 07, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Scoee Scoffer
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
