Unit is only 2 years old
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
SOURCE: frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
SOURCE: Frigidaire Dryer only runs on "low Heat" setting
Mexitronics
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Hello friend, that's a great question!
From my understanding your Frigidaire Affinity dryer is displaying an error code of "E64". An "E64" error code stands for the heater circuit is open. This could be a possible problem with your heater, wiring harness, or even a miscommunication within your dryer. In order to clear out any miscommunication you can perform a reset on your dryer and to do that you need to unplug the power cord for at least ten minutes. If this does not help to resolve your issue I would recommend having a professional technician out diagnose and repair your dryer to help avoid any future issues or unnecessary part purchases. Hopefully this information is helpful. -Matt
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
