Turning TV off and on by TV then by socket
Do a reset to this TV & check. If it do not help you, contact any service technician or the authorized service center. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: my 42 in plasma tv has froze while retuning digi
try doing a hard reset (unplug the TV from the wall, wait a few hours, then plug it back in. If this doesn't fix it, it is most likely that the main board is defective. The control board should also be checked to match the specifications listed in the service manual.
SOURCE: how do I retune a Luxor 16855 television
try to run auto scan to get other available channel on your location.
