I have the Belkin 4-Port Cable/DSL Gateway Router. It has been running fine until last night. A storm came through, so i unplugged all of my computer components from the wall. After the storm was over, i reconnected everything. It all worked as usual. I also acquired a new computer desk, and disconnected EVERYTHING from each and every component, and set everything up on the new desk. Everything worked fine except the router. the router, as stated previously flashes all four of the LAN lights, and the WAN light. They are flashing orange. It will not connect to the internet, therefore i am running through my modem only. Any help would be greatly appreciated.
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
I agree with atl_dragonki.... Do that and check the network cables themselves to make sure they are adequately crimped to the ends of the wires. Plastic shielding should be crimped into the clear connector, not pulled out and loose, leaving just the wires. Good luck!
Hello, This problem it is most likely be the modem is not connected to the appropriate port. Check connecting the computer to the modem to verify the modem is working.
