SOURCE: Installing PrintMaster Platinum 16
The program should give you a choice of Typical Install, Full Install, and Minimum Install. Choose Full Install, however she may still need some of her discs for some of the art since the program may not load all the art anyway.
SOURCE: I bought Printmaster Platinum 16 and used it with
to use the printmaster
choose older programs.
then ask for it to regonise printmaster and set it to win xp
now program will work
SOURCE: Is there an instruction manual for Printmaster Platinum 2.0
Is there any PDF documents on the CD-ROM?
Is there a "help" function within the software?
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
SOURCE: IS THERE A PATCH TO MAKE PRINTMASTER PLATINUM 16
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
