How do you block calls on a samsung SGH-a737
This is found on page 85 of the owners manual..
• Auto Reject: allows you to enable a phone feature which allows you to automatically
reject calls from a list of contacts. Use the Left or Right Navigation key to toggle the
activation of this feature. Select Auto Reject to On. Use the Navigation keys to select
the Reject List, and press the key to see the list of rejected numbers. Press the
key to select an entry from the list. You may add a number manually or by selecting
from contacts. Press the Options soft key, and then Create. Select the Search soft
key for numbers from Recent Calls list or from the Address Book. Press the Select
soft key or the key to make your selection. Press the Save soft key or the key to
save your new selection.
I always use LEO Privacy to help me do this action. It's good at blocking calls, you can have a try with this applock LEO Privacy Applock Hide Safe Android Apps on Google Play
Open the Samsung A737 page at any of these sites: My Unlock Code, GSM Liberty, Unlocking.com or Mobile Unlocked. All four of these are pay sites. Mobile Unlocked and GSM Liberty offer money-back guarantees in case the code will not unlock the phone.
Remove the Samsung A737's battery. When the site you chose in Step 1 prompts you for it, type in the International Mobile Equipment Identity (IMEI) number from inside the Samsung A737's battery compartment. Every site in Step 1 needs the IMEI to generate an unlock code specific to your phone. Pay for the unlock code. In case you do not use a credit card, most of these sites will accept a PayPal payment. You will receive the unlock code by email, usually in a few hours, depending on which site you chose.
Slot the old carrier's chip into the battery compartment, in case the unlock code will not work without it: some unlock codes are network-specific. Put in the battery and close the battery chamber.
Enter your Samsung A737's phone mode. Type on your keypad the code precisely as it appears in the email. If you receive the unlock code "A5966J Send" for example, then type in 259665, and then "send" the code to your Samsung A737 by pressing the Talk/Call/Send button.
Slot the new network's chip in under the battery. Make an outgoing call to test if the phone is now unlocked. If the call does not go through and a chip or SIM error message pops up, repeat Steps 3 and 4 a few times. If you still cannot make a call, contact the code provider so they can remedy the problem.
