Kevin-
LASKO's typically have latches or clips that hold the front fan guard to the back fan guard.
Flip latches or carefully remove the plastic clips. This will reveal the 'nut' that secures the fan 'blade assembly'. Note, the nut has 'lefthand' thread so to remove it, turn it clockwise to remove.
The fan blade assembly can be pulled / wiggled free.
The fan blade assembly can be washed with water / wiped with a cloth.
Another nut (righthand thread) secures the back half of the fan guard, remove it and remove the guard.
That should do it.
SOURCE: Lasko E20739 Fan
I would love to tell you yes, but I ended up buying new fan.
The common wire was broken, buried in the windings and no way to repair without
damaging the windings.
Could not find anything on line.
Sorry,
mrboo747
aka Gary C
SOURCE: my lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I have lasko fan sudenly it stoped oscillating can
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
SOURCE: Cleaning
Model E20739: The entire back comes off to expose the fan blades after removing two screws. Just unplug the unit. On the back of the unit near the top is a recess that acts as a carrying handle. In that area you will see two large silver-colored screws. Remove these, grasp the back of the unit and push down on it as you pull it away from the body of the fan. You may have to wiggle it around a little to free it.
