Question about KitchenAid Microwave Ovens
Kitchenaid architect II microwave won't stop beeping
I can hit cancel repeatedly, i can cut off power, it will still intermittently start doing it. All other functions work.
    New Friend:
  • 27 Answers
Hi Carole,
Dear you most probably have problem with electronic control board in your microwave oven.
It has to be fixed by an Electronic Technician.
If you have knowledge in Electronics then I can help you fix by yourself.
Just let me know
Regards
Ashwin
Posted on Jan 23, 2015
  • I believe you are correct. I am comfortable removing the control board with assistance. I have a tech in town who is able to get the replacement board free under warranty, but I'd rather take it out and replace it with your help.
  • Ashwin Kumar
    Ashwin Kumar Feb 08, 2015
    Ok so you have to be carefull while removing the touch pad lug from main board connector.
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 27, 2008
bruce harrod
  • 112 Answers
SOURCE: Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Posted on Oct 25, 2008
sweet_2010
SOURCE: My Galanz microwave WP800AP20-6 is beeping for no reason
I have similar problem
Posted on Jul 27, 2010
Brian Nelson
  • 4 Answers
SOURCE: KitchenAid built in microwave model #KHMS155LSS-4.
Whirlpool is conducting a safety recall on the Kitchenaid KHMS155L series (and similar models under other brand names) that display the F2 code or have been observed self-starting. Other symptoms may be additional codes or unintelligible info being displayed, and failure to execute the command entered into the control pad. To obtain free replacement of the control panel, call Ava at Whirlpool: 1-866-640-7146, extension 6337. She will want your complete model and serial numbers and a phone number and address where you can be reached. She will arrange for A & E Factory Service to contact you to set up an appointment to come out and replace the control panel at no cost to you.
Posted on Nov 02, 2010
Ge adora over the range microwave, runs but does not heat
Microwaves contain high-voltage parts that can be deadly, even when unplugged, unless handled correctly. Unless you are a qualified expert, don't attempt to get into its inner workings.
First, use this water method to double-check if there is actually an issue with your microwave not heating:
1. Fill a glass measuring cup with water to the 1-cup mark.
2. Set the microwave to heat on full power for 1 minute.
3. Repeat the process with fresh water a handful of times.
4. If the water is not consistently warm, your problem is confirmed.
If your microwave is failing to heat correctly, you may be on a previously programmed setting. Press the STOP/CANCEL button and start the heating process again, but use a higher power setting. This may correct the problem.
If the microwave senses an open door, it will not run. Check to see if a defective or loose door-safety interlock switch is to blame. If tightening it doesn't work, a replacement may be necessary.
Did you know? Neglecting to hit the STOP/CANCEL button on the microwave before you open the door to remove your food damages the safety switch over time.
Microwaves installed above the range may be affected by steam from cooking. Condensation collecting on the circuitry can interrupt heating. Allow the circuitry to dry out by avoiding stovetop cooking for a few days. If you're still having the same problem, it could be a loose connection in the circuitry or a faulty door safety switch.
There may be an issue with the circuit board and its connections, and that work is best left to a qualified professional.
A buzzing or humming microwave that emits a faint burning smell could signal a damaged magnetron, high-voltage capacitor or diode. Replacement magnetrons are expensive, so if a service professional determines that's the problem, you may be better off buying a new microwave. Capacitor and diode parts cost much less, but remember, you'll be paying for the expertise to have them installed correctly and safely. It may still make more sense to buy a new microwave, especially if it's a simple countertop model.
For more troubleshooting steps and simple solutions, read Microwave not heating. I hope this helps!
Sep 28, 2012 | Microwave Ovens
My microwave/convection oven will not heat up, but the lights and clock work
Hello
Look to see if the microwave power cord is securely plugged into a live power outlet. The power cord cannot be loose for proper function. Move other appliances to a separate outlet if possible.
Replace or reset the circuit breaker or fuse if blown or tripped.
Unplug the microwave and wait several seconds before plugging it back in to reset.
Make sure there are no current functions in use. Press "Clear/Off" to cancel any other settings or programs already in progress.
Select a new cooking program and then select "Cook Time." Make a time selection and press the "Start/Pause" pad to begin cooking.
Oct 04, 2011 | Microwave Ovens
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Microwave fails to operate
Sounds to me like a controller problem, if you paid $125 to have the oven fixed and it didn't get fixed, myself I would raise hell.
Tell the repair guy to come back out and fix the thing, I understand about the "call out" charge, and I sure wouldn't pay it the second time, after all he didn't fix the problem, sorry Charlie trying doesn't cut it.
Feb 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
NNP-294 Dead
If you suspect the fuse at all, it's best to replace it.
With the microwave unplugged, if you can easily turn the fuse with your thumb & forefinger while it's in the holder, it has overheated and fatigued and the holder should be replaced.
Simply squeezing the holder's terminals together with pliers is not really a good solution.
An intermittent door switch will not make the unit intermittently dead, it will only make it not heat, and depending on the model, it will also likely make the turntable and inside light not come on. But again it depends on the model.
You may need to clean and/or realign the door mechanism or door switch mounts.
This is especially true in case a user opens the door while it's cooking without hitting Stop first or slams the door. Both are big no-nos for a microwave.
The main parts that will kill the power are the fuse, fuse holder, or thermostat or thermal cutout, which are usually located on or above the magnetron and on the top of the cooking cavity.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2008 | Panasonic NN-P294WF Microwave Oven
Danby microwave m # 1153
danby dmw11536 my microwave oven start beeping all the time. i can start it if ipush the cancel button, ordinarely once but sometimes it won't start unless you unplug it. also disylay shows 1:00 but keep time of cooking anyway. after it returns to beeping all the time, sometime you have to leave it unplugged for a couple of hours. danby dmw11536
Aug 27, 2007 | Microwave Ovens
Microwave power interruption
the unit may be detecting a mal-functioning magnetron.
Jun 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
150 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
