Brother MFC J6720DW together with Vista (HP Probook)get error code CC4-201-00000000 imposible to print although it works from my Win 7 PC. I have tried to enter control panel->system ->services and activate/manual/deactivate print spooler but no improvement.Any ideas?
SOURCE: After a power outage, my Brother printer,
First off, make sure that you have turned both the printer and the computer off and then turn them on(cycle the power). When you go to the printer in 'printers' be sure that the printer is not light in color, if it is, then it's failed to come back online or it's broken. When you say, 'I have tried going into the control panel and clicking on print offline', I take you to mean 'print online', because you don't want to print offline, you want it online...
The easiest way to solve this is to move the usb plug going into the computer from the printer from one port to another, this will force the computer to re recognize the printer. I see that this printer has network capability. I am assuming, that the printer is connected via USB and not Ethernet. [USB, rectangle the size of your pinky, but narrow, Ethernet looks like a big phone plug]. If you move the plug from one USB slot to another and you don't hear the hardware connect sound(low tone then high tone), then your printer may be broken. It is possible if it is broken that the Ethernet port still works, but using that is beyond this discussion.
Good luck,
Brett
SOURCE: Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
SOURCE: black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
SOURCE: Brother MFC-9449CN(CC3-205-03031f04) error message. Scanner
The solution to your problem is in your network. A 205 error is network related with a confusion in where the IP address is. Make sure that you have the right IP address for your brother printer. ALSO VERY IMPORTANT... make sure that YOU DO NOT HAVE a wired AND wireless connecion. This will cause confusion between the printer and PC. It will not know where to send the file. Lastly if you are printing with a gateway connected to a router this could also cause problems. ie comcast gateway connected to router. I currently have a comcast gateway connected to router with no problems. But i also have my gateway in DMZ plus mode(complete unrestricted access for router)
Hope this helps.
to the person who says don't buy brother, I happen to like brother printers. They have been the most stable out of all that we have owned at our office. If you have a cell phone and can not figure it out you get help. the answer can't be don't buy a cell phone.
SOURCE: hi - I purchased a Brother MFC 7360N and hooked it BEWARE SPAM NUMBER 1-800-532-4187
Check to see if the scanner works with the Windows built in Scan and Fax utility. If it does, then download this Twain Reset Utility http://support.visioneer.com/utilities/twain_reset.exe and reboot. Try to use the Brother scanning software after the reboot.
