My chrysler lhs started making a buzzing sound when the radio is on or off, it gets louder when i accellarate. what is this noise?
This is usually indicative of a ground loop causing noise from the vehicle electrical system. Long story short your stereo isn't grounded well enough.
There are two possible solutions:
1. Ground all components to the same point. This will reduce the potential and should greatly reduce any noise.
2. If number 1 is not possible (and it often is not), use a "ground
loop isolator", available at nearly all electronics stores, or car
audio suppliers. This device prevents a direct electrical connection
between the two sources and will usually fix the ground loop.
