Coffee Makers & Espresso Machines Logo
Bonnie Rang Posted on Dec 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a "SHARPER IMAGE" anti fog mirror with am/FM radio from " BED BATH & BEYOND" it was on clearance because it was a display, but there was no box or instructions, its a very simple machine to figure out, the problem I 'm having problems with the suction cups on the back, I cannot figure out how to make them stick! Is there anyway you could look into this very simple problem? Thank you
Inky Fingers
Level 3:
  • Master 705 Answers
  • Posted on Dec 16, 2014
Inky Fingers
Master
Level 3:
Answers
705
Questions
0
Helped
433730
Points
1443
You need to post your question in a more appropriate section. This will get you a more reliable answer.
5 Related Answers
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Apr 22, 2008
SOURCE: instruction manual
Go to http://sumanual.com maybe there you find the instructions.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Dec 15, 2008
SOURCE: We purchased the Cuisinart Classic
The clock does not light up - it is dark and hard to read - normal.
Sergio M Perez
  • 39 Answers
  • Posted on Dec 29, 2009
SOURCE: xp2070
Most likely a defective unit. Hope you got a replacement unit. Mine is working again after replacing the power module and the water flow meter.
Anonymous
  • 28 Answers
  • Posted on Feb 07, 2010
SOURCE: my Keurig B60, 1 month old is not brewing enough coffee
Check the needle inside the k-cup holder to ensure it isn't clogged. You can completely remove the k-cup holder and rinse it out using your kitchen sprayer to help loosen any debris stuck inside the needle. The needle is what punctures the k-cup and extracts the coffee from within the cup and can become clogged. Make sure when you replace the k-cup holder, that you align the arrows and snap the top or arrow-side in first. If simply rinsing your k-cup holder and needle don't do the trick, try inserting the end of a small paper clip into the needle to push out any remaining debris. This technique is actually recommended by the manufacturer, so it won't void any warranty or damage the needle. After replacing the k-cup holder back into the machine, try brewing a cup of coffee to see if it did the trick.
As a side-note, if you regularly use any "Hot Cocoa" k-cups, you need to make sure and immediately brew a cup of just hot water (no k-cup) to help clean it out and prevent the needles from clogging. The Hot Cocoa k-cups are notorious for clogging the needles up thus causing the problem you described above.
Hope that helps...best of luck!
Anonymous
  • Posted on Sep 01, 2010
SOURCE: missing the instruction manual for a breville
You can visit the Breville Support website for the BKC-700XL. The owner's manual and quick start guide are available for download (PDF format) or on-line perusal.
http://brevilleusasupport.com/product/bkc700xl
1helpful
Eucalyptus origins Sheets rips & shredded fabric
Bed Bath and Beyond should be able to tell you who the distributer is for them. Talk to the dist. and they should be able to tell you. You might want to go back into BB&B and look for another set of them. Look on the package and see if they have any info (phone # or web link) to the manugacturer.
I purchases the Nostalgia Electric Cotton Candy Maker Model # PCM-805 yesterday at Bed Bath & Beyond. The directions, scoop and 2 plastic cones were missing. Can these be sent to me? (The store...
I would call customer service at Bed Bath & Beyond and ask for replacement parts. You might have to bring in your receipt. They should have no problem replacing the missing items, and if Bed Bath & Beyond doesn't have the items, they could most likely call the company for you.
2helpful
No sound from radio or CD
First, do you have a cord to plug it in? Make sure it's plugged in. Then turn the unit upside down. Inside the battery department is a "reset" slot. Insert the tip of an unbent paperclip into the opening to reset the unit, display and memory..
Press the power button located on the lower half of the unit and adjust the volume switch located on the lower left of the unit. Sharper Image is out of business. The licensing has been bought by another company. Their customer service number is 877-714-7444. They are not servicing older units but may be able to offer some assistance. The number for spare parts is 888-856-6781.
1helpful
2answers
Need Manual or how to use this!
Press reset button in battery case make sure your plug in also
Press Wave for 2 seconds press + or - to set zone
Press wave set year + or-
Press wave set date " "
Press wave set time to 24 hr real time + or -.
Press wave set to 12 by + or-and it will set temp F
1helpful
Cant get it to power up
I had exactly the same problem. Here is how I resolved it. 1. There is a reset button inside the battery compartment, in the center, between the C cells. Try pushing it with a paper clip or similar item. 2. If that doesn't work, replace the C cells. 3. If that doesn't work, try replacing the lithium backup battery. It is located between the C cells, in a compartment with an arrow. 4. I finally did all three at the same time, replacing the C cells, lithium battery, and resetting the system. The radio has worked fine for two days now. Good luck.
2answers
Sharper Image Beetle projection alarm clock/radio-need ac adap.
You can just buy a regular AC adapter in any store, just ask for a universal AC adapter to make sure it will fit. (you can try Radio Shack, Walmart etc.)
In a universal AC adapter there are multiple plugs and there's switch to set the volts, just find the right plug that fit you Alarm Clock and make sure you set it to 6V and that's it.
Hope it helps
Daniel
Sharper image clock radio for shower
To set tuner presets:
1. Manually tune desired frequency.
2. Press MEMO button, Display will flash.
3. Manually enter memory position, 1-5.
4. Press MEMO button again.
The manual is available as a PDF file from the Grundig web site. Or, if you will e-mail me at deepblack <at>ugaalum<dot>uga<dot>edu and put "Yachtboy" in the subject, I will e-mail it to you
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
